Soft button light up
Hi ALL,
When using a soft button I have found that just touching it lightly and quickly and the command is sent. Touching it a little harder and longer and the same command is still sent but the soft button lights up which to me was a good feedback that the button sent the command.
Shouldn’t the soft button light up even if it was a light and quick touch. Is this a bug or was it intended to be this way? I think it would be more useful if the soft button would light up for ANY kind of press, light of heavy, short or long.
Gerry
