Shutter integration availabilty?
Hello
Is there a way to integrate an electronic roller shutter winder?
Unfortunately, it only has RF as a remote control. However, it also has a bridge and can be controlled via Wi-Fi using an app.
A Broadlink RM4 Pro coupled with Discord works well.
Also a Bond Bridge with Discord.
Is the mentioned bridge a Bond?
I use a bond bridge with both home assistant and the R3. M.a.S.e. created an integration for Bond.
i read this and was like “did i???” and had to check my github LOL. bond is good device, they still maintain the old hub firmware pretty well, it can learn RF commands , if this device has RF high chance bond will support it.
Lol. As long as the device isnt using 868MHz - I have an awning that uses that and to date have still not found a suitable bridge that can learn the commands that also works with HA.
Yes is 868
