Screensaver configuration
The first time it was used, the clock was displayed shortly after it was placed in the charging station. After that, the display turned off. Now I played around a bit and placed a button. The display now changes as follows:
  • Insert into the charging station → clock is displayed
  • a little later the display with room and button appears and then stays that way
I haven’t found a way to stop this behavior. If it doesn’t exist yet, I would like this as a feature:
Set a screensaver and its behavior.
E.g. After time x activate screensaver when in dock. Selectable screen saver (clock, own picture or the normal screen stays on). Or if not in the dock, switch off the display after time x or (if that makes sense at all due to the battery life) display a simple clock with low brightness.
