Hi all I’m new to this and having trouble getting my Samsung set top remote to work it will not set up manually and I can not find hex code anywhere is there a work around maybe home assistant ?
Have you search in the Global Caché database? Database | Global Caché Control Tower
Which model and have you tried learning IR?
Samsung SMT-C5320
I didn’t know it even existed 2 days of googling and never saw it
Thank you
Did you try to learn the IR codes?
I did no go but I did get the codes from the web site
