I’m having a hard time getting the REST API to work in Postman. I keep getting “authentication error”. I am using Basic Auth. Username: admin. But, what password do I use? I have tried blank, remote2, the PIn that appears on the web-config screen of the remote, the Administrator PIN that I created in the setting screen… none of that works.
Try with the username of web-configurator
and the password being the PIN to access the web configurator.
