I have a custom (learned) set of IR codes; one of them is incorrect, I want to either rename it or delete it and re-learn the code. I don’t see a way to do either in the Web Configurator, is it possible?
You can’t rename them as far as I’m aware, but if you select the 3 dots next to one in the web configurator you can then select edit which will allow you to relearn it.
