I have a weird issue whereby every now and then (once a day at the moment), my remote screen flickers when picked up then i pick it up again after screen goes black and it goes back to normal. This time I managed to take a picture of how it looks. Is that something anyone is aware of? Could not find anything in the forums about it.
cobhc
April 29, 2026, 6:33pm
2
It’s a known issue. There’s a bug report here.
opened 12:41AM - 08 Aug 25 UTC
bug
ui
### Is there an existing issue for this?
- [x] I have searched the existing iss… ues
### Description
I just updated my Remote 3 from 2.6.1 to 2.6.5 and noticed some UI artifacts at the bottom of the screen. It looks like a sliced duplication of the top bar.
### How to Reproduce
This issue persists after having updated from 2.6.1 to 2.6.5.
I rebooted the remote a couple of times after the update, but that didn't fix the issue. However, after shutting down the remote and powering it back on, the artifacts disappeared. Then the artifacts at the bottom of the screen came back again. It looks like they reappeared after the remote woke up from sleep.
### Expected behavior
Bottom edge of the screen should not have UI artifacts.
### System version
2.6.5
### What part of the system affected by the problem?
UI
### Additional context
Ah lovely, thanks for the reply!
Mine has done that as well. Typically about once a week.
