Remote Microphone
I am trying to get the Remote 2 dock to learn the code for the microphone button on my xFinity remote but not having success. Does anyone know how or is this a feature that isn’t available? Does the mic work for AppleTV?
On most remotes it is no code you can learn it is an internal function to activate the mic on the remote.
So does that mean that I can’t use the Remote 2 mic feature for either Apple TV or xFinity?
The microphone on the remote has no function at the moment. If you take a look at the software roadmap (Roadmap) you can see that it’s planned to integrate it into Home Assitant first and in Q3 as entity command so that other integrations can use it too.
Sure would be nice if these remotes could trigger HA local voice!
