Manufacturer: Bell Satellite Box
Model: Arris VIP22T1NA
I successfully created all my entities and learned the IR codes for all my remotes, except for my Bell Satellite Box Arris VIP22T1NA / 405. I am really struggling with this one. Whenever I try to learn the remote, I receive an unknown error on the dock. I tried to learn many buttons … Power, Guide, Menu and they all give me an Unknown error message on the dock. I cannot find the right IR codes on Global Cache database. I do not know how to overcome this.
Another code if you can. I have a Samsung 9 series smart TV model KS9000 TV and I am struggling with the code for the Power Toggle. It’s leaning a code but it does not work. I think the code is not correct. Can you help with the right code for this TV ? Thanks.
For some reason the Generic Samsung TV does not work and I cannot use the Android TV integration because the Android TV Remote service required for this integration does not work on Samsung smart TV’s …. unless there exists another integration specific for Samsung TVs which I do not see in the integration setup process.
I am still having intermittent issues with the Power Toggle for my Samsung TV using the integration. Sometimes it works and sometimes not and almost never when part of an activity sequence.
