marton
1
Release 1.7.7 - 2024-03-18
Added
- Public opt-in for beta-software updates.
- IR codes for Lumagen Radiance Pro (#198).
Fixed
- Web-configurator:
- Scrollbars displayed on custom icons page (#336).
- IR-remote button mappings don’t show assigned command in edit dialog.
- Apple TV integration: device is no longer switched on with the switch-off command in standby mode (#349).
- Denon AVR integration: New commands: dpad, menu, context_menu and info. Contributed by @albaintor, thanks! (integration-denonavr#33).
Changed
- Apple TV integration: “menu”-command instead of “settings” for control-center (#56).
Update cookies preferences
