marton
March 8, 2024, 10:50pm
1
Release 1.7.4 - 2024-03-08
Added
Long- and short-press button mappings support in the web-configurator and user interface
(feature-and-bug-tracker#56 ,
feature-and-bug-tracker#90 ,
feature-and-bug-tracker#94 ).
Please note that the additional commands are only supported in the Apple TV integration at the moment. The other integrations will be enhanced with future updates.
New media-player features, commands and button mappings (core-api#32 ).
Show network indicator in entity detail screen.
Apple TV integration:
New media-player features (#56 ):
Multi-device support (#118 ).
Enhanced reconfiguration and manual setup option with IP address.
Propagate entity feature-changes to already configured entities, for example if a device supports more features in a driver update.
This is triggered if the integration driver version changes, or if the user requests the available entities.
Fixed
User interface:
Entity detail screen closed if entity is unavailable.
Media player:
only update the image if image url has changed (#327 ).
do not clear data if entity is unavailable.
button mappings for all device classes.
artwork aspect ratio was incorrect in some cases.
Wrongly showing failed integration setup in some cases, when setup was successful.
Web-configurator: show correct dock LED brightness when set to 0 (#304 ).
Only discover Apple TV 4 and newer devices (#173 ).
Improved disconnect & reconnect handling. This should solve the reported BlockedStateError issues (#300 ).
Automatically wake up Apple TV if a command is sent while it is in standby.
Fast-forward and rewind commands.
Automatically migrate old configuration file at startup and beginning of configuration flow.
Home-Assistant integration: correctly report integration driver version.
Changed
Speed up dock & integration connection logic for Android TV, Apple TV, Denon AVR, Home-Assistant (#320 ).
Entity detail screen can be also closed with long press of Home or Back buttons.
Home-Assistant integration: disconnect from HA server in standby (integration-home-assistant#50 ).
Play/Pause will exit screensaver and continue playing paused media.
Update pyatv client library and other dependencies to fix possible connectivity issues.
Update cookies preferences
