Release 1.7.12 - 2024-05-16
Public release containing all beta releases since 1.7.7.
Fixed
- German translation for cover-entity state “open”.
Beta Release 1.7.11 - 2024-05-14
Added
- Android TV integration: profiles for Philips TV and Dune HD Homatics, new apps. Contributed by @Kat-CeDe, thanks!
Fixed
- Media component image aspect ratio (#350, #369).
- Android TV integration: update androidtvremote2 library to fix a network disconnection error (integration-androidtv#40).
Beta Release 1.7.10 - 2024-04-11
Added
- Support remote-entity in integrations (core-api#44).
- Home Assistant Remote Entity support (integration-home-assistant#23).
Fixed
- German translations for media-player commands “back” and “previous” (#366).
- Web-configurator:
Beta Release 1.7.9 - 2024-04-01
Added
- Major Android TV integration update:
- Support multiple Android TV instances and French translation. Contributed by @albaintor, thanks! (#253).
- New media-player features, long-press commands and device profiles (generic, Google Chromecast, NVIDIA Shield TV for now) (#90, #92, integration-androidtv#34).
- To update already configured entities: click “Reload” in the available entities pane in the web-configurator.
- Kodi app mapping and German setup translation. Contributed by @Kat-CeDe, thanks!
Fixed
- Same Android TV device cannot be controlled by multiple Remote Two devices (#362, integration-androidtv#39).
- Improved reconnection handling (#283).
- Re-authenticate a configured device with an invalid certificate (integration-androidtv#36).
- Power on/off command handling based on device state (#218).
Changed
- Apple TV integration: unique device name prefix for pairing to easily identify paired devices on Apple TV (#362).
Beta Release 1.7.8 - 2024-03-25
Added
- Standby inhibitor management functions in Core-API (required for #136).
