Remote 3 physical buttons unresponsive
Since I installed update 2.73, I encountered a completely new issue (not sure if its related to the last update though):
My remote had reached 15% battery level and I tried to switch channels on an Android TV settop box (Sagemcom DIW7022). Then I got the screen that it couldn’t connect, with the ‘Cancel’ and ‘Retry’ options. I tried to select Retry (3 times), which didn’t work, followed by the Cancel option (once).
After this, while the touchscreen kept working as normal, all physical buttons went unresponsive (including the 3 buttons below the screen).
I then had to end the Activity via the web interface, which was succesful.
I then rebooted the remote. It seemed to reboot normally, but after a few seconds I got the charging screen, the round clock with the battery percentage, but without the ‘Charging’ indication (I guess because the remote wasn’t being charged at that moment)
I placed it in the dock to get a full charge…
…. has anyone else encountered this issue, or am I the first?
