Remote 3 integration for Home Assistant where do I download
I want to add Remote 3 to HA, but it is not built in. Where do I find the file do do so?
A custom home assistant integration to interface with your Unfolded Circle Remote.
(GitHub - JackJPowell/hass-unfoldedcircle: Home Assistant Integration for the Unfolded Circle Remote Two)
To clarify, this is an integration that lives inside home assistant and interfaces with your Remote. I would suggest to join the discord channel allot of users are there.
Thanks. Got it all done via HACS - except when I go it in discovered devices (in HA) it askes for a pin code!! I dont see a pin code on the R3?
I imagine it’s the R3 pincode you set when setting up the remote. Don’t you have to enter an “admin” pin number? Don’t have my R3 but remember that being part of setup although it may be able to be blank. I imagine the R3 is asking for confirmation before joining HA as a security measure or if you had several remotes.
