Remote 3 crashes after update 2.6.12
Is anyone else having problems with remote 3 after installing the latest update (2.6.12)? Every time I update it (3 times now) the screen becomes blank with intermittent glitches. You cannot use it and I have to put it in factory reset mode. This also causes me to loose all my integrations work and entities because I have to start over…
If anyone has suggestions to get past this, PLEASE HELP.
Thanks!
FYI the latest version is 2.7.0 beta
Not for you problem but for the future. If you have a system which is more or less working make a backup. No backup no mercy.
Unfortunately the Backup covers not custom integartions.
Not yet but still it covers most of the work you put into the config. I have > 20 devices with > 20 activities and I would be really mad (p****d off) if I loose my base system.
Is there a timeline for the backup function to include custom integrations?
Not that I know of. For me it would already be enough if the config of custom integrations are saved. Some like LG TV and Kodi already do it their way.
Yes but it would be so much better if we didnt have to backup each custom integration separately and the primary backup function just backed up the entire config including custom.
Thanks everyone for your input. Unfortunately for me, I think I got a lemon :pensive_face:
Both the 2.6.12 and 2.7.0 (beta) leaves my remote blank, glitchy, and unresponsive. I have asked Unfolded Circle to send me a replacement…
yeah, that one crashes my remote also
