Remote 2 instel problemen
Good afternoon, I am currently setting up my Remote 2. My setup is as follows: 1-Epson EH-LS650B-2 VU+UNO4KSE-3 LGSL8YG SOUNDBAR-4 FEINTECH VAX04101. My problem is that when I start a sequence, everything starts up properly; however, my Epson keeps indicating “no signal.” Does anyone know what I need to change to prevent this? (P.S. If I briefly unplug my VU and plug it back in, the picture does appear.)
Please post your start sequence.
I think it might be a timing problem. A projector normally needs quite some time. Try starting your Epson 1st, add a large delay and then the VU. I is only for a test.
Thank you very much for your help; the setup process is quite challenging. Initially, I wanted to use my old Harmony Hub with this Remote 2, but I couldn’t get that to work, so now I’m trying a different approach via Home Assistant. Thanks again!
I also went the Home Assistant route for my R2.
Initially I started out with the R2 + dock just being a Harmony + hub replacement with a connection to Home Assistant, but gradually moved all the logic and smartness to Home Assistant, turning the R2 into a fancy but in all honesty quite dumb Home Assistant remote.
My activities are HA helper switches, which when turned on, start a logic process in HA with a few state polling+failsafe measures in place for reliable sequencing
My button presses and screen touches are HA helper buttons which are being mapped to all kinds of things like sending IR codes or changing channels on my ISP box
My media players are HA media players/remotes shared with the R2. They seem to function exactly like native media players
I’m using a Broadlink R4 mini for IR stuff, which in my case performs a lot better than the dock: the IR power is a lot higher and it handles multiple commands I a sequence better
Thank you for your response. I have been working for two days now—with the help of AI—to integrate my Logitech Harmony into Home Assistant, but I just can’t seem to get it to work; we are clearly doing something wrong somewhere. I’m having particular trouble setting up my Epson EH-LS650 projector. Even the AI ​​is stumped at this point.
What I meant is that the Harmony integration in my Home Assistant—which works fine with my Harmony Elite—doesn’t seem to work with my Remote 2.
Why are you trying to integrate your Harmony? You should move on and either use the remote alone or with HA. There also is a Epson/PJLink integration for the remote that might work better than in HA.
Well, we’ve made some progress, but I’m still stuck with a problem: no matter what I try, I can’t get my LG SL8YG to learn the commands from the original remote control. Do you happen to know a solution?
Well, we’ve made some progress, but I’m still stuck with a problem: no matter what I try, I can’t get my LG SL8YG to learn the commands from the original remote control. Do you happen to know a solution? Even with the help of AI, we haven’t been able to figure it out.
Have you tried the integration for LG soundbars if this works?
If it’s IR controlled I would suggest visit globalcache.com where there’s an extensive IR database where you can download all commands individually.
But if it’s possible to control it over IP or even Bluetooth, that would be the preferred way over IR.
When there is no integration for the remote itself, you could also look for an integration within Home Assistant, mostly obtainable through HACS. And then port that to your remote
Good afternoon. I followed your advice and downloaded and installed the integration, but unfortunately, that didn’t help—even with the help of AI, I tried everything, but the LG [soundbar] just wouldn’t cooperate. I’ve since bought a different soundbar, which worked immediately. The only remaining issue concerns my projector, an EPSON EH-LS650B; it continues to be problematic. When I try to teach it the codes manually, it saves them, but they don’t actually work with the Epson. Do you happen to know where I might find the correct codes so that I can get the power on/off sequences to work properly? Thanks in advance!
If you learned the codes of your Epson successfully use the big IR blaster which has more power. Before you connect it to the dock pull power from dock first.
