I had to reinstall my Home Assistant system.
The problem is with the long-lived access token — it’s gone because I had to completely start from scratch in Home Assistant.
I created a new one and would like to use it with the integration on the Remote 3.
However, I can’t find any option to edit or delete the old token on the Remote 3.
Right now, I have no way to reconnect to Home Assistant.
I also deleted the integration on the Remote 3, rebooted the remote, and reinstalled the integration — but I’m not getting any prompt to enter the new long-lived access token.
Has anyone else experienced this issue?
