@HarmonyFan Ralf your thoughts? This may be a new / different issue than the original screen “interlace” issue given the software versions now involved. Worth a bug report?
I am no expert for display problems. I never had one up to now. Looks like an interlaced image we already saw quite often. Because you use 2.8.2 a bug report cannot do any harm.
@Malignant @mrxree as the issue was believed fixed at previous software levels it would be useful for you two to raise a bug report at this github link: Sign in to GitHub · GitHub. You’ll need to setup up a login to github if you don’t have one.
We’re aware that it’s not fixed for everyone and working on it.
Thanks @marton
I’ll dig around in my logs if they still exist.
Picture i provided is timestamped so i might be able to dig the logs up as well.
Happened again to me last night with the latest beta FW.
Noted that when it happens, the touch screen stops functioning properly as well.
Trying to get my logs out, but for some reason the timing doesn’t work properly.
I know at what time the remote ‘crashed’, so i want to pull the logs from an hour around that period. But when i fence it off and download the logs and they start 2 hrs earlier and stop even before the event occurred.
