Problems with new TechniSat STB
Hi.
I own an TechniSat DIGIT ISIO STC. I imported the Pronto-Codes and everything works perfect.
Now i bought a new STB: TechniSat DIGIT ISIO S4.
Original-Remote works well.
On Remote 3 none of the existing codes work. No reaction on the STB.
So i created a new, empty entity and learned some commands from the original-remote. No reaction on the STB.
Additionally i took the code for the DIGIT ISIO S2 from Global Cahe but the too don’t work.
I tried another STB: TechniSat DIGIPLUS UHD S2
On Remote 3 there too none of the existing codes work. No reaction on the STB.
Here too i created a new, empty entity and learned some commands from the original-remote. No reaction on the STB.
At least i tried my Harmony Elite. It works with all three STB’s without changing anything.
So the problem seem to be on the Remote 3 /Dock3 but i’m out of any idea where to look/search for it.
You can try this from Chris over on the Discord channel. Discord
Tried that from Chris but no reaction on the STB.
I placed it as bug on Github.
After a long time of try & error this is the final result:
The problem lies with the weak infrared signal.
Normally my Dock 3 is about 4.5 m from all entities and controlls all perfect. To control the new STB’s he has to be placed about 1.5 m in front of the STB.
Too the IR-Blaster, which should have three strong ir-emitters, only send from one ir-emitter and therefore ins’t a solution.
Actually i’m in contact with uc-support.
