Working with remote creating activities I noticed that the roku media entity can’t be deleted from activities. Anyone else notice this? or is it just my setup
What do you mean? If you have an activity in the first page (setup?) you see all included entities and if you delete it it´s gone but perhaps also all control options depending on the integration.
yes in the first page where it says included entities, I’ve gone through every part the activity to make sure it wasn’t being used. But I can’t remove it from a activity once it’s added
Did you try to refresh the page or delete the browser cache?
yes and made sure it’ wasn’t some sort of ghost entry i can still assign commands to it so it’s there.
What firmware version are you on? I vaguely remember having this problem (not specifically with the Roku media player) but only for a short period of time.
Just got remote like two weeks ago with 2.90 where i noticed this issue and I just updated to the latest beta 2.91 thinking it might be fixed and not mentioned in change log
not sure if anyone took the time to confirm this but I’ve done a factory reset and updated to latest beta 2.92
symptom if a roku media entity “one with the music note icon” is added to an activity it cannot be deleted the only way to get rid of it is to delete the entire activity and start again.
Same thing here. Did you find a solution for this?
the only solution i found was to delete the activity
