Playstation and Xbox IR codes
Hi, can somebody please share the Xbox Series X IR code set .csv with me please??? I do not want to sign up for Discord just for this. I would really appreciate it!!
Also, if anybody has IR codes for the PS5, that would be great too. Although, I don’t think PS5 accepts IR.
And has anybody tried added their steam deck?
Xbox
key,format,code
EIN_AUS,HEX,3 0x11BF40B 32 0
XBox_Home,HEX,3 0x11B26D9 32 0
1,HEX,3 0x11B807F 32 0
2,HEX,3 0x11BA05F 32 0
3,HEX,3 0x11BC03F 32 0
4,HEX,3 0x11B20DF 32 0
5,HEX,3 0x11BA05F 32 0
6,HEX,3 0x11B609F 32 0
7,HEX,3 0x11BE01F 32 0
8,HEX,3 0x11B10EF 32 0
9,HEX,3 0x11B906F 32 0
0,HEX,3 0x11B00FF 32 0
.-,HEX,3 0x11BB847 32 0
Power_On,HEX,3 0x11B54AB 32 0
Power_off,HEX,3 0x11B946B 32 0
Skip_Back,HEX,3 0x11BD827 32 0
Skip_Forward,HEX,3 0x11B58A7 32 0
Live_TV,HEX,3 0x11B629D 32 0
Y,HEX,3 0x11BE619 32 0
B,HEX,3 0x11BA659 32 0
X,HEX,3 0x11B16E9 32 0
A,HEX,3 0x11B6699 32 0
Eject,HEX,3 0x11B14EB 32 0
Clear,HEX,3 0x11B50AF 32 0
Subtitle,HEX,3 0x11BB24D 32 0
App_Channels,HEX,3 0x11B2ED1 32 0
DVR,HEX,3 0x11B12ED 32 0
Last_Channel,HEX,3 0x11BA45B 32 0
Movies,HEX,3 0x11B8E71 32 0
Play_Pause,HEX,3 0x11B0EF1 32 0
Replay,HEX,3 0x11BA45B 32 0
Standby,HEX,3 0x11B30CF 32 0
TVListings,HEX,3 0x11BAE51 32 0
TVShows,HEX,3 0x11B4EB1 32 0
View,HEX,3 0x11B7689 32 0
Zurueck,HEX,3 0x11BC43B 32 0
hinunter,HEX,3 0x11BF807 32 0
hinauf,HEX,3 0x11B7887 32 0
links,HEX,3 0x11B04FB 32 0
rechts,HEX,3 0x11B847B 32 0
Menue,HEX,3 0x11BF609 32 0
gruen,HEX,3 0x11B6699 32 0
rot,HEX,3 0x11BA659 32 0
gelb,HEX,3 0x11BE619 32 0
blau,HEX,3 0x11B16E9 32 0
Ok,HEX,3 0x11B44BB 32 0
You’re the best! Thank you!
Did you test this one?
CSV file format needs to be: key, code, format.
I have found multiple HEX formated codes but no luck getting them to work yet. Could anybody point to working CSV file with Xbox Series X codes that has been tested?
You can use the set for the 360/One from Global Cache: Control Tower IR Database
I tested it with a Series S. Registration is free and the verification process to download complete sets usually takes less than 24 hours. You will find a lot of tutorials here and on Discord how to import csv code sets from this site or in this general Remote Two guide put together by Mark - giomania from Discord: Unfolded Circle Remote Two Guide 2023-11.docx - Google Docs
Unfortunately I am not allowed to post the codes publicly here due to the terms and conditions of Global Cache but it is worth registering there anyway
I haven’t tested the above codes. However, I do have the 360 set working from global cache. I’ll just use that. Good to know these work!
I have the Remote 3 and XBox SeriesX. Did anybody has the correct IR codes? I wasn‘t able to import these codes as csv :frowning:
Regards moden
Just use the set of codes from global cache for “Xbox one”. Not the ones posted in this forum reply. That’s what I did years ago and I think it tested immediately, which was working fine. I moved my Xbox a long time ago and don’t have a need for IR anymore nowadays with the Xbox. Maybe there’s a web integration now. No idea. But the global cache IR set should still work fine.
