How is it going with the Philips Hue integration. Are there any issues with it?
You can only control individual lights with the hue integration. Scenes are not available. I control my lights with the HA integration and can import scenes - ie “movie time”.
I didn’t try it as I have 3 hubs : I use home assistant integration to control my lights and it works perfectly
