Philips hue integration color & brightness widget
Is there a way to get a color and/or brightness widget on the screen? I remembered seeing it on one of the kickstarter images.
But I cannot find it in the widgets.
That’s only possible with the light entity itself and not a widget. If you add lights to your activity you can also tap on the top bar and then choose one of the lights to get to these controls.
Yes, but that are several extra clicks.
I would like to select this on a user interface page of the activity.
Not possible right now.
