Hi there,
Do you know about a custom integration for Philips hue light?
Because the UC integration is too basic for my usage.
I want be able to access the areas, scenes etc …
Is such existing?
Guillaume
Hi there,
Is such existing?
Guillaume
Hello All
As a work around, I’m considering to use my current harmony hub from home assistant to pilot the lights, but from there all I can do is launch an activity.
Has someone been able to access devices and lights from the harmony home assistant integration?
Thanks for your feedback
Hello All,
As an self answer I will rather use the philips hue home assistant integration which is much better
I am using the supplied Philips Hue integration with my Remote 3, no home assistant . In the past I was able to change the light temp and colour from the remote but it is not possible now, those controls have disappeared. Does anyone have a resolution for this problem please. Cheers
Mine still works, per room I just add the lights to the room I want and have colour temp, colour and brightness.
CyreXx2, thanks for your comment, it got me thinking and after checking the Activity settings I realised I hadn’t added those parameters to the activity after one of my resets/backups. It’s all working now.
Nice one ![]()
