Panasonic TV cannot be switched on or off
I cannot switch on my Panasonic TV with the R3. Not with the preset codes nor if I use the learned ones. TV does not react at all. I can see, that the operation diode does not flicker. Seems, not to receive anything.
Can anybody help?
Thanks in advance!
I just realize, that none of the commands work. Also not the ones I learned from the original remote.
Any ideas?
Have you just tried it with the dock or also with the blaster and internal emitter? For me the dock 3 ir emitters are too weak in comparison to the blaster. The blaster has also better coverage to the front where the dock just fires to the top and very little to the front.
If you tried the Panasonic Generic TV 1 codes from the intenal database you should contact the support if they don’t work.
OK, good hint, with the blaster. I will try. Additionally in the meantime I have checked, that the hub sends signals at all. The smartphone camera shows the pulsation of the diodes, so should be fine.
The internal one in the remote seems not to send anything. At least, I cannot recognize it with the smartphone.
I will try the blaster. It is still in the box. :slight_smile:
The internal remote ir emitter has to be activated first unter development/preview features
Ah OK. I was not aware of this. Thanks.
In the meantime, I have connected the blaster. There is a small one, looking like a drop, and a larger one, looking like a puck. First I tried both, one after the other, than both together, but they didn’t work. After restarting the hub with the blasters connected the puck-shaped one works and now also the the TV switches on. Great! Thanks for your help!
Did you make the same experiance, that the hub needs to be rebooted?
It’s mentioned in the paperwork that comes with the dock that the dock doesn’t support hot plugging.
OK, sorry, I didn’t read it.
