Panasonic DP-UB824 UHD Bluray
Manufacturer: Panasonic
Model: DP-UB824
Does anyone have already this UHD Bluray Player working with the Remote two or Remote 3? IR and/or integration?
I have tried the integration of Albaintor, but Panasonic stopped supporting voice control for this model. About Voice Control | FAQ | Blu-ray Disc Player/Recorder | Digital AV Support | Panasonic
Notice of termination of Voice Control
Please be aware that Voice Control functions of Panasonic Blu-ray Disc™ Players will be disabled after than June 13, 2023.
We apologize for the inconvenience and appreciate your understanding.
Affected Models:DP-UB9004/UB9000/UB824/UB820/UB424/UB420
I use IR on R3 to control my ub824, works fine. When adding a new ir device you can search for vendor panasonic and use the bluray player commands, don’t recall having to resort to global cache codes.
Yes I’m doing the same and the blaster is working well in my media cabinet to control it. I tried the integration and couldn’t get it to work despite flashing the player
The default Panasonic IR code set is not complete for the UB820/824. There was 1 button missing: The PLAYBACK_INFO button. Pronto code:
0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0ACD
Thank you all for your reactions, but I am still missing a reaction of somebody who has the Panasonic Blu Ray integration working.
Like all of you I am currently using IR to control the UB824 on the Remote 3, but I am still trying to get the Home Assistant integration of a Panasonic Blu Ray working, without any success.
Hello Aruit,
I recently activated voice control at my UB424 and IP control is working.
Btw. even with all commands because I use this custom FW:
https://www.avforums.com/threads/lets-try-again-to-put-the-free-in-regionfreedom.2441584/
Long thread - I know… Take a look at #1712.
Thank you MR77.
I have visited item #1712 on the thread and read the DISCLAIMER.
Because I am a Windows mouse clicker and not a Linux user, I did not do the patch.
You need to modify the firmware on the Panasonic for IP control. That’s about #5 on my priorities. I’m trying to still get sequences to reliably turn on and off everything for a handful of my activities.
This weekend I have followed the description in thread #1,711 to patch the firmware and now IP control is working for my Panasonic DP-UB824.
