Hi all,
I’ve just ordered a Remote 3 with Dock. Now i be asked to choose options for color and charging. I think the pictures on their Web-Site shows the Remote 3 in raw aluminium, but where can i find a picture of the Remote 3 in dark grey, the 2nd option? Also they ask for charging and non-charging option. What did they mean with this. I thought the Dock has charging function and the Remote 3 has also wireless charging.
Who can explain?
Many thanks for an answer!
Charging dock: a dock that acts as a cradle to charge your remote
Non charging dock: no cradle but flat surface. In case you want to put in e.g. a closed cabinet to use it as a IR sender. You then charge the remote either in a separate charging dock or wireless charger.
Many thanks for your fast response!
All clear now!
