Oppo "Resource not found" Error
It could be me! I am a luddite! I am trying to configure my UC 3 to work with my oppo bdp 103. I have assigned a static ip address and have loaded Henrik Widlund’s integration driver version 0.0.20. It should work. In fact it does for turning off the oppo! But when I create a sequence to turn on the oppo, it gives me a “Resource not found” message in the web configurator and the oppo does not turn on. I have unplugged the oppo for a few minutes as suggested in another post. That did not work. Any ideas?
Can you publish your On Sequence for the activity?
Right now, I am just setting a test sequence that starts with the Oppo switch on command. I had deleted my previous sequence that included projector on, denon avr on and oppo on. Should I dig out the logs?
Does the Oppo have a static IP? Logs always good.
On my UDP-203, there is a Standby Mode setting under Device Setup that was set to “energy efficient”. I had to change it to “Network Standby” before the player would turn on via the UC3.
Note that this is on the player itself and not in the UC3 configuration.
That being said, it’s still a bit flaky - I had to use the Oppo remote to turn the player on just now to verify the name of the setting.
I believe the unplugging suggestion is to clear out the network buffer in the player.
