Ongoing Problems with LG TV webOS integration
I’ve ongoing problems with the LG TV webOS integration. After a longer time of usage without restart , once a day or every second day, the integration crashes with timed out or bad request errors and I have to restart the remote to get things working again.
This happens also very often if there is a device state conflict (e.g. the TV turns off by itself and the remote believes it is still turned on).
Is there a solution to avoid these crashes, are they caused by the remote firmware or by the integration?
Thank you very much in advance for support,
