So am I just SOL about being able to control my Nvidia Shield Pro (2019) with the Remote Two right now? All my other components are IR, but the NSP uses Bluetooth it appears. Am I just going to have to sit on my hand’s and wait?
Kevin T
Kevin T
The android TV integration works perfectly fine with the Nvidia shield pro. Are you unable to use this in your setup? It’s worked for me since day one.
I’m currently using the Android TV integration as well. It’s almost perfect - it seems like button “press-and-holds” are not currently supported, which is a bit of a pain, I’m hoping that’s a fixable nuisance and not a limitation of the Android TV IP protocols…
Harmony used to emulate the Bluetooth remote, while the Unfolded Circle Android TV integration is IP-based. Did your remote not “discover” the Shield Pro when you were setting it up?
Yes. I am really needing that feature too, but it’s the long press (button hold) that is not currently implemented in the remote at all. It doesn’t support this for any device. But it’s on the roadmap. Eventually it will have this capability. And this remote handles the shield WAY better in my opinion. It’s a direct (IP) integration versus the crummy Bluetooth method. Harmony does handle it pretty good, but this better and more responsive
OK. Thanks! I’ll check that out. I’m starting to realize this remote is way smarter than I am. I came from a Learning IR Home Theater Master then moved to a Logitech Harmony / Hub system. Now I’m clearly out of my element with the Remote Two.
You and me both! I think this product is unique in the sense that (compared to say a Sofabaton) it’s clearly far more extensible - reminds me a little of Control4 in some ways.
But - I do think to help people bridge that gap, we need to be able to access logs from the hubs, and documentation needs to improve (which will of course happen with time).
Hi I have a Formuler Z8 Pro and when trying to add Android TV integration, it finds the device but somehow it got an error trying to set it up:
I have no idea if the integration works for this device. Does someone know the solution?
Thanks in advance!
ps: sorry… I must first install Android TV Remote Service for the integration to work! It is working now… still figuring out how the remote works ![]()
Here we are almost 3 years later and I still don’t see the long press working with any device using the Remote 3.
Huh? You can map any command to a long press action on the button mapping page of an activity
Yes, but the long press command doesn’t do anything after being mapped. For instance, I used the long press a lot on the Harmony remote for the Apple TV 4K device but it won’t work on the Remote 3. Same with long presses on the Nvidia Shield device.
Apple TV works without any issues for me an many others including long press commands.
What commands have you mapped? If it’s for all devices you should create a new thread or better an issue on GitHub with logs and screenshots of your mappings.
It doesn’t work for me. For instance, on Apple TV activity, I’ve mapped the Enter key to “Curser enter” on the choices for that device. On the Harmony remote as well as the original Apple TV remote, some pages will pop-up additional options when doing the long press. On the Remote 3, nothing happens when doing a long press which is also mapped to the same “Curser enter” action. Same thing with Oppo device, the info key will show some information about the current disc and doing the long press on Harmony and original remote brings up additional information which doesn’t work with Remote 3.
You need to map the actual command for that function that is e.g. called context menu for long press enter. The integration doesn’t know how long you pressed a key. The same for the app switcher and control center (Menu). Otherwise the remote will just send a normal cursor enter command. If you don’t map anything to long press the short press command will just be repeated. That’s usefully for the cursor direction buttons for fast scrolling.
Works great using the “context menu” command. I had just been using the same commands as I had on the Harmony remote and wasn’t aware of this one. Thanks!
What about the Oppo player? Is it better to use the Oppo integration or add another IR entity and learn the commands (as I currently have it setup)?
In general integrations should be preferred.
Joining discord is also a good idea. Among other the author of the oppo integration is there quite often.
