I can’t get play/pause and skip forward and back to work via bluetooth
Does anyone know how?
(Remote 3
firmware 2.5.1 installed? In older versions some button of the R3 were not working.
btw. I would not use BlueTooth. I use Android TV for my Shield Pro 2019.
Same for me…
I mean i could controll it via bluetoot (fully functional), BUT after any wakeup from Standby (of the Remote) it did crazy things.
Button presses were not executed immediately and then played in a row, that was really strange.
But i switched to Android TV Integration and that one works well.
I found with Bluetooth on the Shield:
Don’t use the Power on and off commands.
Use Wake and Sleep.
