Notifications of 3rd party integration updates
Apart from this forum and checking regularly on the relevant GitHub pages is there any way to be automatically notified when one of your 3rd party integrations has an update released?
If you have a Github login, then, for each individual integration that you are interested in, you should be able to select the “Watch” option and then select “All Activities”. I haven’t used this myself, however it sounds like it might provide you with the functionality you want.
Thanks. If I select ‘custom’ I can then select ‘releases’ which should work for me.
I have a git account but I check with change detection docker because I check also other things.
Discord
Thanks Harvey. I have a Discord Login but havent used it before. Can you send me an invite link to the relevant server / channel please?
Thanks Harvey
