Hi, last firmware version dates back to june 20. Has development ended?
All the development work is on the new web configurator which is still in beta. If you’re not on the beta channel on the remote then you won’t have received an update in a while. I’m not on the beta and can’t remember the last update the remote had. According to the kickstarter for the remote 3, the new configurator will be released to coincidence with the launch. So probably next few months for general release.
Ok, thx for the update. I was used to having an update every month or two months. Felt like the project was abandoned and focus had shifted to the new remote. But great to read that development is ongoing!
Beta releases are pretty stable and are far more advanced than the current official release. Beta firmware is currently v2.1.0 and stable is 1.7.14. There’s substantial improvement in 2.1.0.
I’m running it on 2 R2’s with no issues in terms of stability or bugginess. I recommend moving to beta releases.
Thx for your suggestion. As I´m currently still testing the remote, and am still relying on my Harmony for everyday use, I might look into switching to beta releases. Just need to make sure I´m able to switch to stable releases easily in the future
Is there a beta change log somewhere? I’m only finding the public one
There is one on Discord: Discord
This is great - thanks
