that being said, i noticed a bug within the xbox, try first to uncheck remote play and then re check remote play again, make sure it is set to sleep and try again (uncheck remote play and re check it, then redo the integration setup and try again).
Major new release:
Microsoft broke authentication flow - version 4.0.0 is out officially, please note the new instructions. Read them carefully. The integration will now take a hybrid approach, you will need to create an app in Microsoft Azure (similar to my Smartthings or Spotify integrations) and then copy a code from a redirect URL. Please read instructions carefully. tested verified working and stable. GitHub - mase1981/uc-intg-xbox: An unfolded Circle Remote xbox controls over IP
I guess I’m lucky as the old method from version 3 still works fine for me. I even set it up from scratch again yesterday and tested it and it all works fine.
Really? That’s really odd. Where are you from in the world? Because for others and myself included Microsoft stopped allowing redirect url. So I had to fix it. Been broken for a while for new users.
It 100% works, I use it as well as others, someone configured it just yesterday. It works. You most likely missed a step during the Microsoft creation side (otherwise it would work)
Either join discord to discuss there. (its alot of more active)
Redo all the steps or provide screenshots on how you set it up on Azure
Integration works. I personally use it as well as others.
Awesome! Glad it works out.
I don’t know why for some old vs new works. Why I wrote both options, Microsoft don’t publish any of this to help so it’s best effort from my end. But glad you got it sorted out at the end.
