Hello All,
I have purchased the remote 3 and it should arrive next month.
I must say I’m very excited to receive it and start with it.
I’m now trying to deep dig into how I will manage this new remote.
It will replace an Harmony Elite.
Here is my configuration:
Sony projector XW5000
Video Processor Lumagen Radiance pro 4242
Audio Processor/Amplifier Onkyo RZ3100
Fire TV 4K
UHD Bluray Oppo UDP203
Media Player Zappiti Reference
Light Philips hue
Currently, everything is controlled through IR, and I guess I can safe start using the harmony hub integration.
However, I would like to take the opportunity of this new remote to build something more modern and reliable as a control.
All my gear will be connected to my network with cable (no wifi except for the harmony hub, and the philips hue hub).
If it helps, I can consider to add a home assistant I currently don’t have, which from my understanding drastically extent the possibilities.
My understanding is that Philips hue is natively compatible with the remote, so no problem with that.
Is one the other equipment natively compatible for the remote?
Can the other become through home assistant?
Is there one for which I will have to stick with IR?
I assume activity can mix equipment whatever the origin (IR, HA, UC integration), right?
And another question:
WIth the Fire TV, is it possible in an activity to launch an application automatically at the start of the fire TV, and then have activity like watch youtube, watch amazon, and the activity is turning on the fire tv and launch the application?
Many thanks in advance for your helpfull advice based on your experience or knowledge.
Regards
Guillaume
