Naim Audio Integration
Hey Everyone, I am releasing my new integration for Naim Audio, disclaimer: i do not own a Naim Audio device so this integration was built “Blindly” using a simulator. I did receive a lot of help from @kika1992 and @Gillyshere (Thankyou!!!) so please if there are any issues, i will be unable to replicate therefore in github i also providing a naim_device_discovery.py script. if the integration is missing buttons that you have in your current Naim device, run the script (using python) and send me the json output. Addionaly, since i will be unable to replicate, any issues, please provide a log. This integration will give you a Media Player and a remote entity with all buttons (well, hopefully lol). Thank you.
https://github.com/mase1981/uc-intg-naim
New update up
New version up.
New verison up. post investigation; there is no direct API for the above sources in NAIM devices. Took logic from the naim app. Source now filtered out + add deep browse using device real browsable/playable/totalCount fields; leaves play via ?cmd=play. the select entity reflects the active streaming source when playback is started from the Naim app.
new version up. fix volume physical remote buttons
