My UC Remote 3 is due by the End of April
Im new to the UC R3 but have been doing a lot of reading and viewing the posts on Discord too.
Having programmed the old URC980 and then used the Harmony and Sofabaton X1S I am eagerly waiting for the remote to arrive.
I understand that there is a bit of a learning curve, but happy to spend time working on it.
I also noticed that there were some Videos put together to get people off the ground in Discord.
Would anyone else have any suggestions on where to start and how to go about setting the remote up.?
I have an Anthem AVM 60, with Foxtel STB (Yes, I am in Australia), OPP BDP-83, Pana UB820, Samsung TV and the Valerian Max Projector. My speakers are all Seatons…CATS, Sparks, SubMs….
Thanks for reading …and if you can point me to videos / Newbie starting points etc. I would be very appreciative….
Cheers all
Kris
https://youtube.com/playlist?list=PLk745VcQoUFaRUZ_yBoxe_7trjnMxugBk&si=GqSopHJz_OKLC8RK
I honestly think that, until you first start messing with it, none of those videos will make any sense. That’s how it was for me.
I can give you a quick rundown though.
Check out this post I just made for you here:
