My remote 3 is on it's way
What’s the first thing I should do? I got a Emotiva RMC1L processor, a TCL 98 QM9K, a Nvidia shield Pro and a Panasonic Blue Ray.
New here, Thank you.
join the discord channel, go to the community projects section and there you can find the custom integration for all your devices minus the panasonic one i think. you should watch a few videos to learn how to interact with this remote. and for almost every question you might have someone gave an answer, search her and you most likely to find.
https://youtube.com/playlist?list=PLk745VcQoUFaRUZ_yBoxe_7trjnMxugBk&si=GqSopHJz_OKLC8RK
I think TCL works with Android TV/Google TV so Android TV integration should work like for the NVidia. For Panasonic the is a community integration. Here a list of current integrations:
It is important to understand the underlying concept of the remote and the taxonomy. E.g. what is an entity, activity, activity group or an integration. Have a look at the support pages on the unfolded website and there are a few videos on YouTube that might be helpful.
From there, I personally would start setting up devices via infrared (if possible) and create a few activities to get started. After that, you can check if there are other ways to control your devices like the integrations mentioned above.
I will join the group. Thank you.
