My personally valuation of the Unfolded Circle 3
Hi!
First of all: the remote is nice and works perfect!
  • the design of the remote is great, altough it would be better for me to have 4 phyiscal colour buttons eg for teletext or functions of a vuplus (so I have to put them on the touch screen).
  • I’m happy that I can define sequences and use them in different actions - eg turn on/off projector, screen down/up etc. With Logitech Harmony or Sofabaton you have to double and triple these sequences every time.
  • Also the integration in homeassistant is good.
  • I like to configure everything via web interface and not by app.
  • The remote looks noble and it is good to use.
  • The touch screen is great enough to settle buttons, sequences, tv-logos etc and works pretty good
All in all - it’s a very good product.
But lets go to the really worst characteristic of the remote - it’s the battery life time!
When using it how a remote has to be used (you take the remote in the hand and push buttons and they should work immediately) you have to configure the remote not to go in standby.
With this configuration, the battery drains just by lying on the table and doing nothing with nearly 5% per hour. When using it every now and then, the remote will be on low battery within a few hours.
This is not acceptable! The Logitech Harmony works some days without loading it. The Sofabaton X2 is working for 2 weeks without loading.
I would by satisfied if the battery holds 2 days without loading.
The main problem is either a to weak battery or respectively to much wastage, or in my opinion the complete wrong technical concept of the remote.
Actually all operations are done by the remote by itself.
It would be much better to delegate the operations to the dock via bluetooth and only transfer media content (which I believe this is the exception) via wifi.
This concept is done by Logitech and Sofabaton - both have no negative issues with battery life.
Maybe there is a possibility to solve this problem which I believe is a problem for all users.
Keep on going your great work!
greetings from Innsbruck / Austria / Europe
raimund
That’s the reason why I bought the Sofabaton X2 and why I’m much happier with it than with the Remote 3.
The Remote 3 is a great remote control, but unfortunately it has the wrong concept.
Maybe there will be a Remote 4, who knows.
I personally spent weeks configuring the Remote 3 — testing this here, adjusting something new there.
Everything was fine in principle, but the battery kept draining too quickly, and I was no longer willing to live with that problem.
Since switching to the Sofabaton X2, I no longer have these issues. It’s not as beautiful or premium but it works great.
I was able to connect Home Assistant without any problems and quickly map my entire home cinema setup. As of today, it’s by far the better remote control — at least for me.
If a Remote 4 with a hub comes out, I would definitely give it another try, but the Remote 3 is unfortunately a misdevelopment.
I noticed the same issue with the battery. Beautiful remote and it feels premium, but the battery life is subpar. I shouldn’t have to keep it on the dock so often.
Agreed, the battery life is not ideal. And the frequent “Device is not responding - the command did not reach the device” messages are annoying. Having to lift the remote, wait a beat and then pause whatever you’re watching is by far the biggest flaw with it.
