Is there a way to add more than 1 apple tv, that are in seperate rooms to the apple tv integration? so far my Remote 3 is only allowing 1. Trying to figure out the best solution for my other one.
Just run the integration setup again and you will have the choice to add additional devices.
Ive tried that and it doesnt work. I keep getting an error. if i delete the one i have it will show both but once one is added it will not let me add any more
For the 2nd did you try it twice in a row? There was an error that the second does not show an entity at the end you must repeat setup again then an entity to add is shown.
Or just click on the + button above the configured entities list after you completed the setup. There is a general bug that no entities show up to be added after the setup is completed.
