More frequent “Try again” messages after wake-up with 2.9.5 Beta
Since updating to 2.9.5, the green display artefacts are completely gone, so thank you for fixing that.
However, I have noticed another issue. After waking up the remote, I now quite often get a “Try again” message when pressing a button. Usually the second or third press works normally.
This happens with different activities and different devices, so it does not seem to be related to a specific integration. It feels like the remote is not yet fully connected immediately after wake-up.
Has anyone else noticed this behaviour on 2.9.5?
If you did not configure “prevent sleep” in you activities the remote goes to bed after a few seconds after each action and needs to reconnect to WiFi or at least the entities of integrations. Since a few month an automatic resend of failed commands is in the firmware. You can configure it only direct at the remote. I think default is retry for 3 seconds I set it to 10 seconds. If command is send before 10 seconds are over it stops resending.
btw. current firmware is 2.9.11
Thanks for the explanation!
I already have the automatic retry enabled, but I’ll check the retry timeout and try increasing it to 10 seconds.
What surprises me is that this behaviour became much more frequent after updating to 2.9.5. Before that, I would occasionally see a “Try again” message, but now it happens almost every day after waking up the remote.
I’ll test the retry timeout and also check my activity settings. Thanks for the tip!
And yes, I noticed 2.9.11 is available now. I’ll update and see if it improves the wake-up behaviour.
