Missing Media Widget progress bar
How can we get the progress bar?
No one will be able to fix this, only me as this is from the LG Horizon integration. Its a feature addon, just need time to do this. You asked, i will work on this. But i need some time, it’s weekend - spending some time with family :slight_smile: i wil try to incorporate that. its not controled by UC - its per integration development, not a setting that can be turned on or off etc.
No problem Meir, I will wait until you have time.
