Media Widget Question
The image for the media widget gives the impression that it’ll show detail meta data of what’s currently playing.
I’m using an NVidia Shield and thus far through a handful of apps (Kodi, Netflix, Hulu) I’m only seeing the app icon.
Do I need to set something up? Feature for a later time?
Sadly hardly any App is providing neccessary infomation. For Kodi I would advice the Kodi integration which delivers additional information.
Thanks Ralf, kinda what I figured. Could you point me towards more info on Kodi integration?
Here you find a link to the git, go to releases, download the tar.gz file and upload in in the R3.
Ral
I’m running an R2 - is this integration different that what I’m presently using?
Which integration do you mean? Until there are no special integrations for R3.
The one you linked to right above. Is the AndroidTV integration different for the R2 and R3?
R2 and R3 are running almost the same firmware (Unfolded OS). Thereforce you don’t need to check for any compatibilty when looking for integrations.
If you want widgets you must configure Chromecast features on.
The link I posted is a list of available integrations and if the dev is unfolded circle they are the ones included in the firmware.
