Magnetar udp800 mk2 ip control
I just recently purchased the magnetar udp800 mk2 and I’m trying to figure out how to install this configuration onto my Remote 3. I very new at using the configuration system. I have learned how to put the nvidia shield and the AVM 70 8k on the remote, however i haven’t found any topics about the Magnetar. Please send help to me. Thank you.
Latest release of Magnetar integration can be found here along with instructions. GitHub - henrikwidlund/unfoldedcircle-oppo: Unfolded Circle integration driver for the Oppo Blu-ray players · GitHub
Thank you, it worked great. Now i just need to learn micro’s
Hi, can you tell me where you found the AVM 70 integration and installation instructions? I would really appreciate it since I can’t find it.
