Losing connection to dock
I have problems to stay connected to the dock.
Everything works fine when connected but when losing the connection I have to restart everything.
Rob
Have you tried to change the dock url/IP in the dock settings to the real ip address instead of the .local domain?
Hi Kenny,
Do you mean a fixed IP adres in the web configurator dock settings?
Rob
Yes, exactly
Oke I did this and stil loose connection.
Now I use a wired connection to the dock and see if this wil help.
Rob
How do you know that you are losing the connection to the dock? Is it missing from the list of connected devices in your router?
The dock is not required for configuring the remote. It is just a charging cradle with IR LEDs.
Because my remote tels me when I push a button.
And when I take a look at the dock in the remote it keeps reconnecting.
Rob
I had the same problem. I found the usb cable was not making a good connection. I used a different power supply and usb cable and the problem went away.
