Manufacturer: Eversolo
Modell: DMP-A6
I am searching for working IR codes for Power Toggle, Power On, Power Off to use with the Remote 3.
The Eversolo can be switched on by IR or button press only.
I found this code 0x4D (Ascii Hex NEC1 protocol). But I do not know how to transform it into Proto syntax.
I also tested the power codes from Zidoo, but they did not worked.
I hope somebody can help me with some codes.
