Long press: add duration on ENTER key for LG TV?
Hello
I use LG integration to remote control my TV LG G2.
On the original remote control, you can long press the ENTER button to open context menu, it’s another command that the short key press which is not available on the LG integration.
How to set the original long press ENTER button? Maybe a time duration on the ENTER button from the LG integration?
This is what works for me:
Add command context menu to long button press of ok.
