Lexicon / Arcam integration
Hey there! Remote Two is a wonderful accessory to control my home media setup. I have installed the 2.0 beta with Apple TV, LG WebOS and Sonos integration. My AVR Lexicon MC-10 is controlled via IR.
Would be really nice to control that device via IP too, as it has an IP and serial connection. Any chance there will be a custom integration? I think the Lexicon stuff is pretty similar to the Arcam devices, which are more popular…
If you’re running Home Assistant, you can add the Arcam HA integration (Arcam FMJ Receivers - Home Assistant) which will then let you control over IP from your R2 through HA.
I found that Home Assistant has made both my R2s so much more powerful. I have IP control over my NAD AVR and Sony Bravia TV on my main setup and my Yamaha AVR and LG TV on my secondary setup.
