Having got the R3 working with solely IR boxes, for sometime I was frustrated with commands being intermittently missed. e.g. pressing up/down 5 times the cursor would only move 4 times. Thinking it was a WiFi network problem I tried moving docks and then connecting via Ethernet, changing the R3 from auto to 2.4G/5G but nothing seemed to help.
Going through the R3 WiFi & Bluetooth settings I disabled the Active WiFi scanning which was set to 10 seconds and my problem is now solved. I don’t know if this setting is default or if I tried this when investigating an earlier WiFi problem. I can only think that the missing commands were when the active scanning took place.
Does this sound possible?
Steve.
