Hi ALL,
Got an e-mail a few days ago from FedEx that my R3 was on the way and I just got it today. So I wanted to share my first impressions.
First I was a little surprised that it was overall smaller than the R2. About the same length but quite a bit narrower. But still it felt well built similar to the R2.
Next, during the initial turn on I could not connect to my Wi FI, either 2.5 or 5, after several tries each. My router is nothing special and all my other devices connect to it with no problem. So I had to skip the Wi Fi connection and move on. After finishing the rest of the initial setup and knowing I couldn’t do much until I connect to Wi FI, I tried again and it connected on the first try! Why it failed initially and now worked I have no idea!
Knowing I was getting the R3, I made a backup of my R2 this morning. Then I told the R3 to recover from that backup, and MUCH (MUCH!) to my surprise the R3 was up and running with the same programming that was in the R2! I was a little hesitant to even turn the R3 on as I was worried that it could mess up my R2, which I am now COMPLETELY dependent on. But I was assured that the R2 and the R3 can co-exist without any problems. And they both are now working. I did have to do a little re-mapping of some of the hard buttons but that was trivial, even with the new interface which I have not updated my R2 to.
So, my initial impression is quite positive! I’m going to use it instead of the R2 for a while and decide which to make my daily use remote. Then the other will be powered down and be a backup in case the daily use remote dies for some reason.
My R2 is set up as 100% IR control because when I set it up the integrations were new and not as stable as they should be. And yes, I know the newer integrations will probably work but even with IR control everything works as I want it to about 99% of the time. Sometimes a device misses an IR command but, again, most of the time it works quite well. So, at least for now, I have no intention of updating from IR control.
And I’m still concerned about updating the R2 since one of the versions “bricked” the R2. So, again, if it works I’m not touching it.
Thanks again to many here who helped me get the R2 to work in the first place!
Gerry
P.S. I’m in the US and I fully expected to get some indication that I had to pay a tariff but I never got anything!
